English
Error: Bad login user [Microsoft SQL Server Native Client 10.0: Cannot execute as the database principal because the principal "sde" does not exist...
Error Message
When upgrading an ArcSDE geodatabase within SQL Server to version 10.0, the following error message may be encountered.
[O-Image]
Code:
the database principal because the principal "sde" does not exist, this
type of principal cannot be impersonated, or you do not have permission.]
Bad login user
Cause
When upgrading the geodatabase to version 10.0, a direct connection to the geodatabase as an administrative user is required.
If using an SDE schema and the SDE login does not exist and/or is not synchronized with the SDE database user, the above error is received and the upgrade cannot be completed.
Solution or Workaround
See the article 'Re-synch SQL Server logins or users after restoring a database from backup' in the Related Information section for specific steps on synchronizing the login/user within SQL Server.
    Related Information
