English
How To: Install IIS 7 with Tomcat 6.0.18 using J2SE JDK 6 Update 16 for ArcIMS 10 on Windows Server 2008, Windows 7 and Vista
Summary
Instructions provided describe how to install and configure IIS 7 with Tomcat 6.0.18 using the J2SE Development Kit (JDK) 6 Update 16 for ArcIMS 10 on Windows.
Specific information for the installation of ArcIMS is included in the product's installation guide.
This procedure requires the following software: This installation also requires a user account that has Administrator rights on the ArcIMS machine.
Before Beginning
Familiarity with certain Windows tasks is required to install and configure ArcIMS. For details, see Common Windows tasks when installing ArcIMS.
For more information on the acronyms and terms used in this document, refer to Glossary of terms used in ArcIMS Installation articles.
Review and follow Steps 1 and 2 from the ArcIMS Installation Guide. These two steps ensure that the system meets the minimum requirements and assist in planning the ArcIMS site configuration.
Previous versions of ArcIMS must be uninstalled before proceeding. The setup program for ArcIMS on Windows prompts for the removal of previously installed versions.
If ArcIMS components are distributed among several computers, before continuing with the installation, remove the components on each computer by going to Add/Remove Programs and selecting Remove for ArcIMS.
Procedure
Warning:
If ArcGIS Server is already installed and running on the same Web site where ArcIMS is to be installed, then IIS is being run in 32-bit mode. Follow the steps for 32-bit installation.
  1. Uninstall any unsupported versions of Java, Web Server, or Servlet Engine. For more information, refer to How To: Uninstall ArcIMS-related third-party software on Windows.
  2. Install Java 2 Standard Edition Development Kit version 6 Update 16.
    A. Click J2SE Development Kit (JDK) 6 Update 16 to download Sun Java 2 SDK, Standard Edition, version 6 Update 16.
    B. Click Download JDK.
    C. Select a platform, and accept the license agreement.
    D. Click the download link for Java SE Development Kit 6u16. The file jdk-6u16-windows-i586.exe is downloaded.
    E. Run the installer after it has finished downloading.
    F. Accept all of the default installation options, unless changes are required. This installs both the Java Runtime Environment (JRE) and the Development Kit.
    Registration of Java is optional.
    G. Navigate to Start > Settings > Control Panel > Java. On 64-bit machines, from the Control Panel select the View x86 Control Panel Icons folder.
    H. Click the Update tab, and uncheck Check for Updates Automatically.
    I. Click Apply, and close the Java Control Panel.
  3. Install Microsoft IIS if it is not already installed.
A. Navigate to Start > Control Panel > Programs and Features.
B. On the left, click Turn Windows features on or off.
C. On the left, Click Features.
D. Scroll down and under Features Summary, click Add Features.
E. In the Add Features Wizard, expand Remote Server Administration Tools, expand Role Administration Tools, and check Web Server (IIS) Tools. Click Next.
F. Click Install.
G. Once complete, click Roles on the left.
H. Click Add Roles.
I. In the Add Roles Wizard, click Next, check Web Server (IIS), and click Next twice.
J. In the Select Role Services window under Web Server > Application Development, check
  • ASP
  • ISAPI Extensions
  • ISAPI Filters
K. Scroll down, and under Management Tools > IIS 6 Management Compatibility, check IIS 6 Metabase Compatibility. Click Next.
L. In the Confirm Installation Selection window, click Install.
M. In the Installation Results window, verify that the installation was successful, and click Close.
N. Once complete, restart IIS by clicking Start and typing IISRESET in the Search box. Or go to Administrative Tools > Services and restart the IIS Admin Service and World Wide Web Publishing Service.
O. Open the IIS Manager by navigating to Start > Programs > Administrative Tools > Internet Information Services (IIS) Manager.
P. Expand the server host name and Sites on the left. Select the Default Web Site.
Q. Under Default Web Site Home, right-click on MIME Types, and select Open Feature.
R. In the Actions panel, click Add to open the Add Mime Type dialog box.
S. Type 'axl' in the File name extension field. Type 'text/xml' in the Mime Type field. Click OK.
Warning:
The version of Tomcat used in this article is 32-bit, thus the 32-bit version of Java must also be used (including 64-bit machines).
  1. Install Tomcat 6.0.18.
    INSTALL TOMCAT
    A. Go to the Apache Tomcat 6.0.18 Download Site.
    B. Click apache-tomcat-6.0.18.exe to download the file. Save it on the local machine.
    C. Navigate to the download folder, and double-click apache-tomcat-6.0.18.exe.
    D. Click Next.
    E. Read the License Agreement, and click I Agree.
    F. In the Choose Components dialog box, change the type to Full install, or alternatively, only select the Service and Examples features.
    G. Click Next.
    H. Select the preferred installation location; for example, the default C:\Program Files\Apache Software Foundation\Tomcat 6.0 or C:\Tomcat6.0.
    I. Select the default settings in the Configuration dialog box. Create a new password for the Tomcat Administrator. Click Next.
    J. If the path is not set automatically, map the path of the installed JVM to the location of the Java Standard Development Kit; for example, C:\Program Files\Java\jdk1.6.0_16. Click OK.
    If a path to an older SDK version is listed, cancel the Tomcat installation. Make sure that a Java SDK is installed, and make sure that the environment variables, JAVA_HOME and PATH, do not include any old entries regarding the Java Runtime Environment and that they are pointing to the J2SDK location correctly.
    K. Click Install to continue. Click Finish.
    SETUP OF ENVIRONMENT VARIABLES
    L. Right-click My Computer, and click Properties > Advanced tab > Environment Variables button.
    M. Under System Variables, click New. When prompted for Variable Name, type JAVA_HOME, this is case sensitive. For the Variable value, type the path where Java 2 SDK is installed; for example, C:\Program Files\Java\jdk1.6.0_16. Click OK.
    N. In the System variables list, scroll to the Path variable, select it, and click Edit. In the Variable Value text box, add the following to the end of the text, including the semicolon to separate it from previous entries:
;%JAVA_HOME%\bin.
O. Verify that old references to JAVA_HOME in the path variable have been removed; for example, <drive:>\jdk1.3.1.
P. Click OK twice to close the Properties window.
  1. Configure Tomcat for IIS.
    DOWNLOAD CONFIGURATION FILES
    A. Download the configuration files for Tomcat: 6.0.13:Tomcat6013_IIS_IMS93_win.zip.
    INSTALL IIS REDIRECTOR FOR TOMCAT
    B. Extract the downloaded .zip file to a location on the hard drive.
    C. Navigate to <Tomcat installation directory>\bin in Windows Explorer.
    D. Create a new folder, and name it 'win32' in the bin folder.
    Important: If using a 64-bit machine, create a folder 'win64' instead.
E. Copy the isapi_redirect.dll from the location where it was originally extracted, to the newly created win32 folder; for example, <Tomcat installation location>\win32.
If using a 64-bit machine, copy the file isapi_redirect_1.2.27_amd64bit.dll to the 'win64' folder and rename it isapi_redirect.dll.
CONFIGURE PROPERTIES FILES
Important: If using a 64-bit machine, replace any paths referencing the /win32 directory with /win64 in the steps below.
F. Copy the files 'workers.properties.minimal' and 'uriworkermap.properties' from the temporary location, from step A, to <Tomcat installation location>\conf.
MODIFY WEB.XML FILE
G. Navigate to <Tomcat Installation location>\conf, and open the file 'web.xml' in a text editor.
H. Search for the following text:
<!-- The mapping for the invoker servlet -->
<servlet-mapping>
	<servlet-name>invoker</servlet-name>
	<url-pattern>/servlet/*</url-pattern>
</servlet-mapping>
Delete the comment lines '<!--' and '-->,' so the code appears as shown below:
<servlet-mapping>
</servlet-mapping>
I. Search for the following text:
	<servlet>
		<servlet-class>
	  org.apache.catalina.servlets.InvokerServlet
		</servlet-class>
		<init-param>
			<param-name>debug</param-name>
			<param-value>0</param-value>
		</init-param>
		<load-on-startup>2</load-on-startup>
	</servlet>-->
Delete the comment lines '<!--' and '-->', so the code appears as shown below:
	<servlet>
		<servlet-class>
		</servlet-class>
		<init-param>
		</init-param>
	</servlet>
J. Save and close the file.
K. Edit the file 'context.xml.'
  1. Find the file 'context.xml' in <Tomcat installation directory>\conf, and open it in a text editor.
  2. Add the parameter privileged="true" into the <Context> tag at the beginning of the file. The first two lines of the file should look like this:
<!-- The contents of this file will be loaded for each web application -->
<Context privileged="true">
  1. Save and close the file.
CONFIGURE THE REGISTRY
Warning:
It is recommended that you backup your operating system and files, including the registry, before proceeding. The instructions below include making changes to essential parts of your operating system. Consult with a qualified computer systems professional if necessary.
Esri cannot guarantee results from incorrect modifications while following these instructions. Therefore, use caution and proceed at your own risk.
The registry file Win_IMS93_IIS_Tomcat60.reg is configured for Tomcat 6.0.13 installation at the location C:\Program Files\Apache Software Foundation\Tomcat 6.0. If Tomcat was installed to C:\Program Files (x86)\... or a custom location, open the file in Notepad, and make the appropriate changes to reflect the installation location.
If ArcGIS Server is installed on the same machine as ArcIMS, then IIS is being run in 32-bit mode. In this case, it is necessary to adjust the second line in the registry file to read:
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Apache Software Foundation\Jakarta Isapi Redirector\1.0]
L. Double-click the registry file Win_IMS93_IIS_Tomcat60.reg in the location where it was extracted to execute it.
M. Click Yes and OK. This creates the necessary registry keys for Tomcat.
CONFIGURE IIS
N. Open Internet Services Manager.
O. Under Internet Information Services, expand the contents of the host machine name.
P. If a Jakarta virtual directory already exists in IIS, delete it.
Q. Create, or re-create, a Jakarta virtual directory as follows:
  1. Right-click Default Web Site, and select Add Virtual Directory. This opens the Virtual Directory wizard.
  2. In the Alias box, type Jakarta.
  3. 3. For Physical Path, browse to <Tomcat installation location>\bin\win32. Click OK.
R. Add Jakarta ISASPI filters as follows:
  1. Click Default Web Site, and from the list on the right, double-click ISAPI Filters.
  2. In the top right of the screen, select Add.
  3. Type Jakarta for the Filter name.
  4. For the Executable, navigate to <Tomcat installation location>\bin\win32\isapi_redirect.dll.
  5. Click OK.
INTEGRATED WINDOWS AUTHENTICATION
S. In IIS Manager on the left, navigate to and click Default Website, double-click Authentication, and click Anonymous Authentication. Verify that it is enabled.
T. Navigate back to Default Website, expand it, and select Jakarta. Double-click Authentication from the middle panel. Click Anonymous Authentication. Verify that it is enabled.
U. Click Jakarta. Double-click Handler Mappings. If ISAPI.dll is disabled, select Edit Feature permissions, and enable Execute.
ADD ISAPI RESTRICTION
This is equivalent to setting up a Web Service Extension in IIS 6.
V. Add an ISAPI restriction as follows:
  1. Under Connections on the top left, click the host name of the machine.
  2. From the IIS list on the right, double-click ISAPI and CGI Restrictions.
  3. In the top right of the screen, select Add.
  4. For Description, type Jakarta.
  5. For the ISAPI path, navigate to <Tomcat installation location>\bin\win32\isapi_redirect.dll.
  6. Check the box to Allow extension path to execute.
  7. Click OK.
  1. Configure the directory permissions for IIS and Tomcat.
A. Open Windows Explorer.
B. Navigate to <drive>:\<Java Home Directory>.
C. Right-click the directory, and select Properties.
D. Select the Security tab.
E. Add the following accounts:
  • Authenticated Users
  • IUSR_<machinename> or IUSR
F. Set the following permissions for the above accounts:
  • Read & Execute
  • Read
  • Write
G. Navigate to the <drive>:\<Tomcat Home Directory>\bin\win32 folder.
H. Right-click the *.dll file. Select Properties.
I. Select the Security tab.
J. Add the following accounts:
K. Set the following permissions for the above accounts:
  • Read & Execute
  • Read
  • Write
  1. Restart IIS and Tomcat.
    A. Go to Start > Settings > Control Panel > Administrative Tools > Services.
    B. Right-click the Apache Tomcat service, and select Restart.
    C. Right-click the IIS Admin service, and select Restart. Click Yes if asked to restart the other services.
    D. Verify that WWW Publishing Service is started. If not, start it.
  2. Verify IIS and Tomcat were installed successfully.
    A. Open the Windows Services panel. Select the Apache Tomcat service from the list and start it.
    B. Enter this case-sensitive URL into a browser:
    http://<your_machine_name>/examples/servlets/servlet/HelloWorldExample
    A page that says 'Hello World' displays if the test is successful.
    Warning:
    If this test fails, check the URL carefully for case or spelling issues. Retrace the installation steps. The URL may work if 'http://<hostname>:8080/...' is specified. This only indicates that the Tomcat Web server is working on port 8080; the required redirect to IIS is failing.
    C. Return to the IIS Management Console > Default Web Site > Properties. Check the ISAPI Filters tab. Verify that there is a green, upward arrow next to the Jakarta filter.
    This only applies to IIS 6; IIS 7 does not have a way to check if the ISAPI filter is working.
    Warning:
    If there is not a green arrow next to the Jakarta filter, stop and re-start the IIS Admin Service, including the WWW Publishing Service, from the Services panel. If that does not work, open a browser, and type 'http://localhost' to re-initialize IIS. If the Jakarta filter still fails, do not proceed further. Go back and verify the settings created in the previous steps.
    D. Return to the IIS Management Console > Default Web Site > Jakarta. Verify that the Jakarta virtual directory is pointing to the correct location on the hard drive, the location of the isapi_redirect.dll.
  1. Install ArcIMS from the installation DVD/download. Refer to 'Step 3a: Installing ArcIMS' in the ArcIMS Installation Guide.
  2. To configure ArcIMS and run the ArcIMS Post Installation, see 'Step 3b: ArcIMS post installation setup' in the ArcIMS Installation Guide.
  3. Verify that the ArcIMS installation was successful.
    A. Navigate to Start > Programs > ArcGIS > ArcIMS > ArcIMS Diagnostics.
    B. Verify that the Web server protocol and the Web server name are correct, including the domain and port number. The default is port 80.
    On Windows XP/2003 machines, Internet Explorer sometimes does not show the host name and port number. If this is the case, right-click near the top of the window, and select Allow Blocked Content.
C. Test both components.
The results for Test 1 should be:
IMS v10.0.0
Build_Number=183.1916
Version=10.0.0
Test successful
The results for Test 2 should be:
Version=10.0.0
Build_Number=183.2159
Test successful
If these tests are successful, the ArcIMS Application Server and ArcIMS Servlet Connector are configured correctly. If an error message is received, select the error number from the drop-down list, and click View. The error number and a description appear. Follow the instructions in the description to fix the problem, and run the Diagnostics tool again.
  1. For additional steps in ArcIMS, refer to Steps 4 and 5 in the ArcIMS Installation Guide.
To get the ArcIMS Web ADF for the Java Platform or for the .NET Framework setup, refer to the following Installation Guides:
Related Information
