HOW TO
Re-create the application configuration file
Summary
If the application configuration file gets deleted, the instructions provided describe how to re-create it.
Procedure
  1. From the Windows Start menu, select ArcGIS Explorer > Application Configuration Manager.
  2. In the 'ArcGIS Explorer Application Configuration' dialog box, select 'Create a new application configuration'.
  3. In the 'Create Application Configuration' dialog box, specify the name and file name for the new application configuration. Provide values for 'Name:' and 'File:'. Select 'Create'.
  4. In the 'ArcGIS Explorer Application Configuration' dialog box, select 'Preview', which launches ArcGIS Explorer.
  5. In ArcGIS Explorer, using the pearl (the globe icon), select 'Set Application Configuration'.
  6. In the 'Application Configuration' dialog box select 'Browse...'. Select the newly created application configuration filename.
  7. Select 'Update'.
  8. Select 'Restart Now'. This opens ArcGIS Explorer.
Article ID:000011093
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
