ERROR
Failed to create the database. FDO error: -2147221231 [GDB_Items]
Error Message
When creating a new personal or file geodatabase, the following error displays:
"Failed to create the database. FDO error: -2147221231 [GDB_Items]"
When trying to open an existing personal or file geodatabase that opens on another computer, the following error displays:
"Failed to connect to database.
This release of the GeoDatabase is either invalid or out of date. [Invalid Geodatabase release]
XML Parser initialization failed."
Cause
The computer is missing the correct version of XML.
Solution or Workaround
Install MSXML 4 SP3 from the Related Information link below.
    Article ID:000011068
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
