English
Problem: What should be done with the *.dat file that is received from authorize@esri.com?
When e-mailing an authorize.txt file to authorize@esri.com, a *.dat file is received from authorizer@esri.com.
Cause
For security purposes, e-mail servers, most commonly Microsoft Exchange, may convert attachments to *.dat files. This behavior is heavily dependent on the e-mail server configuration. See the e-mail server administrator for details.
Solution or Workaround
When an authorize.txt file is uploaded to authorize@esri.com a 'Response File' denoted by the '*.respc' or '*.resps' extension is normally returned. Depending on the security requirements and configuration of the e-mail server, particularly with Microsoft Exchange, this '*.respc' or '*.resps' file is converted to a *.dat file.
There are two possible solutions to this issue.
Solution 1
Provided the conversion process has not corrupted the attachment, rename the *.dat file accordingly:
For licensing ArcGIS Desktop: *.respc
For licensing ArcGIS License Manager: *.resps
Double-click the authorization file to complete the authorization process.
Solution 2
If the ArcGIS License Manager is being authorized, use the workflow provided in the following knowledge base article, "HowTo: Authorize ArcGIS License Manager 10 Offline (by way of email or file upload)", to run through the authorization process a second time.
Related Information
