English
Problem: ArcGIS Server 10 (for .NET) Manager login page displays a blank page
ArcGIS Server Manager Service displays a blank page, which causes the Manager login page to display a blank page.
[O-Image]
Cause
This problem may be due to an incompatible version of the .NET Framework, as described below.
Additionally, this problem may be caused by installing a service pack for ArcGIS Server .NET. Please see the article in the Related Information section.
Solution or Workaround
  1. Clear the contents inside the Temporary ASP.NET file folder and restart the ArcGIS Server Manager Service.
  2. Locate the file Temporary ASP.NET File at the following path:
    C:\WINDOWS\Microsoft.NET\Framework\V.2.x\Temporary ASP.NET File
    The versions of the .NET Framework are different depending upon ArcGIS Server version.
    The following are the compatible versions:
    • ArcGIS Server 9.3.1 - .NET Framework version v2.5
    • ArcGIS Server 10 - .NET Framework version v3.5
Related Information
