English
Bug: Locator properties dialog "OK" button is disabled when locator is stored in SDE
The 'OK' button is disabled for the Address Locator Properties dialog when the locator is stored in SDE, even when some properties have been changed.
Cause
Some properties don't trigger that the locator has been updated and will not enable the 'OK' button.
Workaround
Check/Uncheck any Output field checkboxes to enable the 'OK' button.
    Related Information
