English
FAQ: Is Python Win installed in ArcGIS Desktop 10?
Question
Answer
No, with ArcGIS Desktop 10 the Python Win32 extension is no longer installed, but any existing scripts created using win32com still work properly. PythonWin32 setup is available on the installation media for the following products:
• ArcGIS 10 Desktop
• ArcGIS 10 Engine Runtime
• ArcGIS Server Workgroup 10
• ArcGIS Server Enterprise 10 for Windows.
The PythonWin32 extension setup requires an existing installation of Python 2.6.2, which is installed by the ArcGIS Desktop, ArcGIS Engine, and ArcGIS Server setups.
Esri has developed a new Python module to support the latest version of Python on multiple platforms such as Windows, UNIX, and Linux. ArcGIS no longer installs PythonWin because the recommended methodology for creating the geoprocessor now uses this new Python module.
Install the PythonWin program, pywin32-212.win32-py2.6.exe, found on the installation CD. This will install win32com and enable the existing scripts to work as they did before.
