BUG
Some topology error fixes do not work in ArcGIS 10
**This issue has been resolved in ArcGIS
10 Service Pack 1**
In ArcGIS 10, when attempting to correct certain topology errors using the built-in fixes, the fix may not work or the following error message may be displayed:
"Failed to create new feature."
This scenario is most commonly encountered with the 'Must Not Have Gaps' topology rule and the 'Create Feature' fix, which may produce the error. This issue can also occur with other topology rules, such as the 'Merge' fix for 'Must Not Have Pseudonodes' or the 'Simplify' fix for 'Must Not Self-Intersect' or 'Must Not Self-Overlap'.
Cause
This is a known issue at ArcGIS Desktop 10 that has been addressed in
ArcGIS 10 (Desktop, Engine, Server) Service Pack 1.
Workaround
Install ArcGIS 10 (Desktop, Engine, Server) Service Pack 1.
    Article ID:000011016
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
