PROBLEM
Saved ArcGIS 10 authorization files received via a Microsoft Exchange Server might be blank
Saved ArcGIS 10 authorization files received by way of a Microsoft Exchange Server might be blank.
Cause
The problem arises because the Exchange Server might strip out the XML data contained in the attachment while saving the file as a security measure.
Solution or Workaround
If a *.respc or *.resps file has been received from Esri Customer Service by way of email and it is not possible to save the file correctly by way of MS Outlook or MS Outook Web Access, forward it to a Gmail, Yahoo, or Hotmail account and download it.
    Article ID:000011013
    Software:
    • ArcMap
    • ArcGIS Engine
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
