BUG
Some TIFF images do not align with feature data in European locale in ArcGIS 10
If the regional setting is set to a comma delimited locale such as German or French, some TIFF images with a spatial reference containing scale factor or inverse flattening parameters display in the wrong location.
Cause
Projection parameters such as scale factor and inverse flattening are not handled correctly in comma delimited locales.
Workaround
The ArcGIS 10 (Desktop, Engine, Server) Raster Format Patch (QFE-DT-10-163179) is now available. Installing the patch resolves this issue.
    Article ID:000011012
    Software:
    • ArcGIS Server
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
