HOW TO
Restore the default layout of the ArcGIS Workflow Manager application
Summary
The ArcGIS Workflow Manager application persists the last location of 'tabs' when the application is reopened. This information is stored in a file named 'jtxuiconfig.xml'.
Procedure
Instructions provided below describe how to restore the default application layout for the ArcGIS Workflow Manager application.
  1. Open Windows Explorer and browse to the appropriate location.
    For Windows Vista/Windows 7/Windows Server 2008:
    Code:
    C:\Users\<your login>\AppData\Roaming\ESRI\JTX
    OR
    For Windows XP/Windows Server 2003:
    Code:
    C:\Documents and Settings\<your login>\Application Data\ESRI\JTX
  2. Delete the 'jtxuiconfig.xml' file.
  3. Open the Workflow Manager application. The 'jtxuiconfig.xml' file is re-created at that location with the default layout.
Article ID:000011010
Software:
  • ArcGIS Workflow Manager
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
