BUG
When attempting to change the break values to apply to a greater range of values, the maximum value can be adjusted to a value larger than that contained in the raster; however, the minimum value can not be changed to a value lower than that contained in the raster.
This is a known issue with the Classified renderer.
Get help from ArcGIS experts
Download the Esri Support App
