English
Bug: Connection to an ArcSDE 10.0 for Oracle geodatabase crashes when DISABLEDC is set to TRUE (1)
When the ArcSDE for Oracle geodatabase server configuration parameter DISABLEDC is set to true, connection to the geodatabase crashes due to a network I/O error.
Cause
ArcSDE 10.0 for Oracle geodatabase always uses an internal describe cache and the server configuration parameter, DISABLEDC, must be set to FALSE.
Workaround
Make sure the server configuration parameter, DISABLEDC, is set to FALSE (0).
