BUG
Calculating X and Y coordinate values using the Calculate Geometry tool generate out of range values if the calculation is based on a projected coordinate system (PCS).
This is a known limitation at ArcGIS 10.
Change the coordinate system of the Data Frame to a geographic coordinate system (GCS) and perform the geometry calculation using the GCS.
Get help from ArcGIS experts
Download the Esri Support App
