ERROR
An unexpected failure occurred. The row contains a bad value [LAYER]. The row contains a bad value [Direction]
Error Message
The COGO Cul-de-sac command returns the following error:
"An unexpected failure occurred.
The row contains a bad value [Direction]."
Cause
This is due to one or more fields in the attribute table not large enough to contain the data the Cul-de-sac command is attempting to enter.
Solution or Workaround
Reduce the number of decimals used for Display Angles in Editor > Options > Units tab.
  1. Click the Editor button on the Editor toolbar and select Options.
  2. Click the Units tab.
  3. Change the value for Display angles using to 0.
[O-Image] Display angles using 0 decimal places
  1. Click OK.
Article ID:000010924
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
