HOW TO
The following information is specific to any Python developers who have installed a third-party Python module through any of the following:
-setup.py install
-easy_install
-pip install
The Python build process for C extensions in distutils strips the Visual C++ Runtime dependency from its embedded manifest. Since ArcMap.exe works as a side-by-side application, the interaction between the two fail to find the MSVC runtime DLL, which causes the module to fail on import.
This applies only to the extensions that are built manually from 2.6.5 and includes .pyd files as part of their install. There are no problems with pure Python code or anything built on 2.6.2.
Get help from ArcGIS experts
Download the Esri Support App
