PROBLEM
A layer in a map service that uses an ODBC connection is unavailable if the connection to the data source has been interrupted.
An ODBC connection is handled differently than an SDE connection. If the connection between ArcGIS Server and the ODBC data source is broken, restarting the map service is required to recover the data.
Get help from ArcGIS experts
Download the Esri Support App
