ERROR
An error occurred while processing your request" on deploying WebApplications in WebLogic 10.0 and Oracle Application Servers at AGS Java 9.3.1
Error Message
Deploying Web applications at AGS Java 9.3.1 in WebLogic 10.0 and Oracle Application Servers displays the following error message:
"An error occurred while processing your request."
Cause
At ArcGIS Java 9.3.1, the SOAP toolkit has been upgraded to the new ArcGIS Web Services (AgsJWS) toolkit. All new applications created through ArcGIS Manager or the Eclipse/Netbeans plug-ins will use the new ArcGIS Web Services (AgsJWS) toolkit.
Solution or Workaround
Add the application server-specific deployment descriptor files in the \WEB-INF\ folder for WebLogic 10.0 and Oracle Application Servers 10G R3 shown in the following code example, respectively:
If using WebLogic 9.2 or WebLogic 10.3 as a WebLogic user, it is not necessary to make changes to the deployment descriptor file (weblogic.xml).
For WebLogic 10.0:
Code:
[XML]
<?xml version="1.0" encoding="UTF-8"?>
<!-- weblogic.xml -->
<weblogic-web-app>
<container-descriptor>
<prefer-web-inf-classes>true</prefer-web-inf-classes>
</container-descriptor>
</weblogic-web-app>
For Oracle Application Server 10GR3:
Code:
[XML]
<?xml version="1.0"?>
<!-- Orion-web.xml -->
<orion-web-app
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="http://xmlns.oracle.com/oracleas/schema/orion-web-10_0.xsd"
deployment-version="10.1.3.0.0"
jsp-cache-directory="./persistence"
jsp-cache-tlds="standard"
temporary-directory="./temp"
schema-major-version="10"
schema-minor-version="0">
<web-app-class-loader search-local-classes-first="true"/>
<web-app/>
</orion-web-app>
The presence of these files does not affect deployment to other application servers.
Article ID:000010861
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
