English
How To: Delete custom styles
Summary
Instructions provided describe how to remove a style that can be created (arrangements of the map window, database window, layer window, territory window, etc.) to fit a workflow.
Procedure
When creating and naming a BusinessMAP style, a file is created. Remove the relative file to remove the file.
  1. In Windows Explorer, go to the C:\program files\businessMAP\STYLES directory.
  2. Delete the file with a .wsp extension that has the name of the style created; for example, myunwantedstye.wsp.
  3. After the file has been removed, the related style is no longer in the Styles menu when BusinessMAP is started.
