HOW TO
Print only the selected database records/fields
Summary
After selecting the desired records in the BusinessMAP database window, it is possible to 'Copy Selection' and 'Export Selection'. Instructions provided describe how to print only the selected records.
Procedure
  1. Change the database view so that only the selected records are displayed by using the Database > Selection Mode > Show Only Selection command. It is possible to also use the selection button in the Database window toolbar.
  2. Whereas the above step is relative to the rows of data, it is possible to use the Database > Fields command in BusinessMAP to select and show (and print) only the desired columns or fields.
Article ID:000010835
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
