English
Problem: Cannot see Excel 2007 .xlsx files in ArcCatalog or in ArcMap Add Data dialog box
Cannot see Microsoft Excel 2007 .xlsx files in ArcCatalog or in ArcMap Add Data dialog box, even when a valid Excel 2007 spreadsheet exists and is a supported ArcGIS Desktop input format.
Cause
The file 'GxObjFactCache.dat' is corrupted. This file is located at:
C:\Documents and Settings\<user>\Application Data\ESRI\ArcCatalog\GxObjFactCache.dat
Solution or Workaround
Delete the corrupted file (GxObjFactCache.dat) located at:
The next time ArcCatalog or the Add Data dialog box in ArcMap is accessed, this file is regenerated.
