English
Error: Unable to drop an st_geometry spatial index that is marked as loading in Oracle
Error Message
When dropping an st_geometry spatial index in Oracle, the following error message is encountered:
Code:
SQL> DROP INDEX shape_idx;
drop index shape_idx
ERROR at line 1:
ORA-29952: cannot issue DDL on a domain index partition marked as LOADING
Cause
When creating the st_geometry spatial index, the operation fails for some unknown reason and leaves the index status in a LOADING state.
In this example, the session is attempting to create a local spatial index on a partitioned table and specifies an invalid SRID in the parameters arguments.
Code:
SQL> CREATE INDEX shape_idx ON point_events (shape)
INDEXTYPE IS sde.st_spatial_index
PARAMETERS('st_srid=6 st_grids=.5') LOCAL;
create index shape_index on point_events (shape) indextype is sde.st_spatial_index
ERROR at line 1:
ORA-29855: error occurred in the execution of ODCIINDEXCREATE routine
ORA-20083: Parameter ST_SRID 6 does not exist in ST_SPATIAL_REFERENCES table.
ORA-06512: at "SDE.SPX_UTIL", line 836
ORA-06512: at "SDE.ST_DOMAIN_METHODS", line 1258
Solution or Workaround
To drop an index requires using the FORCE option with the DROP INDEX command.
Code:
SQL> DROP INDEX shape_idx FORCE;
Index dropped.
