Frequently asked question
In ArcGIS 10, is the Command Line window being replaced by the Python window?
Answer
The Command Line window is deprecated in ArcGIS 10, and the Python window takes its place. The syntax used is exactly the same in both.
The Python Window can be accessed from the standard toolbar in ArcMap.
Access to The Python Window in ArcMap
[O-Image] Access to the Python Window in ArcMap
Article ID:000010787
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
