PROBLEM
Parcels created during a parcel construction cannot have duplicate names, or they will be saved as unjoined parcels
Parcels created during parcel construction cannot have duplicate names, or they will be saved as unjoined parcels.
Cause
If parcels created during a construction have duplicate names, they will be saved as unjoined parcels.
Solution or Workaround
After building a parcel construction, do not name any of the parcels identically in the same construction.
If having the same name for more than one parcel is desired, then give the parcel a temporary name, save the construction, re-open the job, and rename the parcels individually.
    Article ID:000010752
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
