BUG
When searching by date on the Geoportal search or administration pages, the dates are values that do not follow the Gregorian calendar and may increment or decrement in the search interface with each consecutive search, such as in the example shown here.
The Geoportal Web application relies on Java to provide the date for metadata registration, search by date, harvesting time stamp, and other functions. This is problematic because Java returns a date based on the locale of the Java Virtual Machine (JVM), which may not be based on the Gregorian calendar. Users in countries where the geoportal server system locale does not use the Gregorian calendar, such as in Thailand, may experience this behavior.
Code:
set JAVA_OPTS=%JAVA_OPTS% -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djava.util.logging.config.file="%CATALINA_BASE%\conf\logging.properties" -Duser.language=th -Duser.region=US
Get help from ArcGIS experts
Download the Esri Support App
