ERROR
The ArcGIS Explorer SDK is not correctly installed - 'ESRI.ArcGISExplorer.targets' not found - (ArcGIS_E3SDK='')
Error Message
Building an ArcGIS Explorer Add-In project in Visual Studio 2008 results in the following error message in the Build Errors window in Visual Studio:
"The ArcGIS Explorer SDK is not correctly installed - 'ESRI.ArcGISExplorer.targets' not found - (ArcGIS_E3SDK='')".
Cause
The Visual Studio process does not correctly read the new environment variable set in the ArcGIS Explorer SDK installation.
Solution or Workaround
Reboot the machine after installing the ArcGIS Explorer SDK before attempting to build an Add-In project.
Article ID:000010741
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
