Summary
Instructions provided describe how to configure ArcGIS Server Java on Windows to utilize SQL Server (Express) as an External Security Datastore.
Procedure
- Install Java Runtime Environment (http://www.java.com/en/download/index.jsp).
- Install ArcGIS Server Java 9.3, 9.3 Service Pack 1, or 9.3.1.
- Install .NET Framework 2.0
- Step 4 - Install SQL Server Express 2005 (English Version)
* Enable Mixed Mode Authentication during install.
* Make sure to install SQL Server Management Studio Express. - Configure SQL Server Express as follows:
A. Open SQL Server Management Studio Express > Create Database Named: "ArcGISPrincipalStore".
B. In SQL Server Configuration Manager > Network Configuration > Protocols for sqlexpress > TCP/IP > ENABLED.
C. In SQL Server Configuration Manager > Network Configuration > Protocols for sqlexpress > TCP/IP > Properties > IP Addresses:
a. Delete all entries for "TCP Dynamic Ports".
b. IPAll > TCP Port > 1433.
c. Restart SQL Server. - Install the JDBC Driver for SQL Server 2005 using the following procedure:
A. Download and unzip the JDBC Driver from: http://www.microsoft.com/downloads/details.aspx?FamilyID=99b21b65-e98f-4a61-b811-19912601fdc9&displaylang=en to: C:\Program Files\Microsoft sql Server JDBC Driver 2.0.
B. Run the following command:
Start > Run > set CLASSPATH=.; C:\Program Files\Microsoft sql Server JDBC Driver 2.0\sqljdbc_2.0\enu\sqljdbc.jar; C:\Program Files\Microsoft sql Server JDBC Driver 2.0\sqljdbc_2.0\enu\sqljdbc4.jar;.
C. Copy C:\Program Files\Microsoft sql Server JDBC Driver 2.0\sqljdbc_2.0\enu\sqljdbc.jar & sqljdbc4.jar to: C:\Program Files\ArcGIS\java\manager\config\security\lib. - Setup the External Database Security Store (SQL Server) in ArcGIS Server Manager:
A. Open ArcGIS Server Manager > Security > Settings > Security Store > Configure�
a. Choose External Database > Configure�
b. JDBC Driver: com.microsoft.sqlserver.jdbc.sqlServerDriver.
c. JDBC URL: jdbc:sqlserver://localhost:1433; databaseName=ArcGISPrincipalStore.
d. Username: sa.
e. Password: <SAPASSWORD>.
f. Test Connection / OK > Next > Finish.
g. Restart the ArcGIS Server Object Manager Service.
h. Log out and log in to ArcGIS Server Manager.
