English
Error: C:\Program Files\ArcPad 8.0\Desktop Tools\cabhead. This application has failed to start because the application configuration is incorrect
Error Message
When creating CAB files with the 'Get Data For ArcPad' wizard, the following error occurs in ArcPad 8.0 Service Pack 1 (SP1):
"C:\Program Files\ArcPad 8.0\Desktop Tools\cabhead
This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem."
This same error may occur with the following path: C:\Program Files\ArcPad 8.0\Desktop Tools\CABHEAD.exe
Cause
This is a known issue, since the Microsoft C++ RunTime was removed from ArcPad 8.0 SP1.
Solution or Workaround
To resolve this error, install Microsoft Visual C++ 2008 Redistributable Package (x86) on the computer running ArcPad 8.0 SP1 from the following link: Microsoft Visual C++ 2008 Redistributable Package (x86).
The Microsoft Visual C++ 2008 Redistributable Package (x86) should be included in Windows XP SP3.
