HOW TO
Create new internal SOAP and REST end points for ArcGIS Server for the Java platform
Summary
Instructions provided describe how to create new internal SOAP and REST end points for the built-in Tomcat Web server at port 8399 on the ArcGIS Server for the Java platform. Additional or alternative SOAP and REST end point names may be preferred or required within the same built-in port 8399.
Also, creating new SOAP and REST end points might help to troubleshoot connectivity and usability problems with ArcGIS Server on port 8399.
Procedure
While the concepts presented here apply to both the Windows and Unix/Linux platforms, the steps provided are for ArcGIS Server for the Java platform on a Windows environment.
  1. Copy the source rest.war and services.war files from C:\Program Files\ArcGIS\java\manager\software to a temporary folder.
  2. Rename the copied WAR files to new SOAP and REST handler names, for example, newservices.zip and newrest.zip.
  3. Extract the compressed files newservices.zip and newrest.zip files.
  4. Copy the two new folders to: C:\Program Files\ArcGIS\java\web_output.
  5. Edit the following file using a text editor, such as NotePad: C:\Program Files\ArcGIS\java\manager\service\tomcat\managerappserver\conf\server.xml.
  6. At the bottom of this file, copy the following line: <Context path="/arcgis/services" docBase="../services"/>.
    Paste the line that was just copied below the existing one, and change the value to a new SOAP end point name, for example, 'newarcgis/newservices'.
    The new line should look like the following: <Context path="/newarcgis/newservices" docBase="../newservices"/>.
  7. In the same file, copy the following line: <Context path="/arcgis/rest" docBase="../rest"/>.
    Paste the line that was just copied below the existing one, and change the value to a new REST end point name, for example 'newarcgis/newrest'.
    The new line should look like the following: <Context path="/newarcgis/newrest" docBase="../newrest"/>.
  8. This part of the file should now look like the following:
    Code:
    <Context path="" docBase="../"/>
    <Context path="/arcgis/kml" docBase="../kml"/>
    <Context path="/arcgis/wms" docBase="../wms"/>
    <Context path="/arcgis/enterprise" docBase="../enterprise"/>
    <Context path="/arcgis/explorer" docBase="../explorer"/>
    <Context path="/arcgis/manager" docBase="../manager"/>
    <Context path="/arcgis/applications" docBase="../applications"/>
    <Context path="/arcgis/server" docBase="c:/arcgisserver"/>
    <Context path="/arcgis/sdk" docBase="../sdk"/>
    <Context path="/arcgis/tokens" docBase="../tokens"/>
  9. Save this file and close the text editor.
  10. Make a backup of the following file: C:\Program Files\ArcGIS\java\web_output\newservices\WEB-INF\classes\arcgis_wshandler.properties.
  11. Copy the following file: C:\Program Files\ArcGIS\java\web_output\services\WEB-INF\classes\arcgis_wshandler.properties to overwrite the existing file located here: C:\Program Files\ArcGIS\java\web_output\newservices\WEB-INF\classes\arcgis_wshandler.properties.
    Alternatively, the existing arcgis_wshandler.properties file can be edited manually, but the password cannot be encrypted. The edited file should appear as follows:
    Code:
    arcgis.som.domain=server_name
    arcgis.som.username=arcgismanager
    arcgis.som.password=arcgis_manager_password
    arcgis.som.password.encrypted=false
    #cluster type can be none or failover or roundrobin
    arcgis.som.resource.clustertype=none
    arcgis.som.resource.hosts=server_name
    #recheck failed som after n incoming request
    arcgis.som.recheckfailedsomcount=100
    #List of foldernames to allow; the default is blank, causing all folders to be allowed
    #set timeout for check tile file access. Timeout unit is second.
    arcgis.webservice.generatedtileaccess.timeout=60
    arcgis.som.foldernames=
    arcgis.webservices.relativeurls=false
    arcgis.webservices.security.authenticationtype=NONE
    arcgis.webservices.security.roles=.
    arcgis.webservices.security.tokenserviceurl=
  12. Make a back up of the following file: C:\Program Files\ArcGIS\java\web_output\newrest\WEB-INF\classes\server.properties.
  13. Copy the following file: C:\Program Files\ArcGIS\java\web_output\rest\WEB-INF\classes\server.properties to overwrite the existing file located here: C:\Program Files\ArcGIS\java\web_output\newrest\WEB-INF\classes\server.properties.
    Alternatively, the existing server.properties file can be edited manually, but the password cannot be encrypted. The edited file should appear as follows:
    Code:
    com.esri.rest.HOST=${Host}
    com.esri.rest.DOMAIN=server_name
    com.esri.rest.USER_NAME=arcgismanager
    com.esri.rest.PASSWORD=arcgis_manager_password
    com.esri.rest.PASSWORD_ENCRYPTED=false
    com.esri.rest.SOAP_URL=http://server_name:8399/arcgis/services
    com.esri.rest.SOAP_HTTPS_URL=
    #Secondary Hosts (for failover / roundrobin), if any - comma separated. e.g. host2, host3
    com.esri.rest.SECONDARY_HOSTS=
    #If secondary hosts are specified, the type of server cluster. Valid values are: failover, roundrobin
    com.esri.rest.SERVER_CLUSTER_TYPE=${ServerClusterType}
  14. Go to Windows Administrative Tools > Services and restart the 'ArcGIS Server Manager Service' and 'ArcGIS Server Object Manager' services.
  15. (Optional) To test the changes, the two new internal SOAP and REST handlers can be accessed in a Web browser using the following URLs:
    http://<server_name>:8399/newarcgis/newservices?wsdl
    http://<server_name>:8399/newarcgis/newrest
  16. (Optional) To test the changes in ArcCatalog, go to ArcCatalog > GIS Servers > Add GIS server > Use GIS services > Internet URL. Type in the following URL: http://<server_name>:8399/newarcgis/newservices.
Article ID:000010700
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
