BUG
When using ArcMAP's identify command with a spatial view referencing a point feature class stored as st_geometry, the following error message is returned:
"Nothing found".
The SQL statement used to query spatial views is missing commas that separate the selected attributes in the select list. The query fails with an underlying DBMS error, ORA-00923, that is not being reported to the end user in ArcMap.
Get help from ArcGIS experts
Download the Esri Support App
