PROBLEM
Edits to a relationship class do not sync between disconnected replicas
When working with disconnected replicas that synchronize using a geodata service, records added or deleted from a relationship class do not sync to the relative replica.
Cause
The replica is created from a map service with geodata access using ArcMap, and the attributed relationship class does not exist inside a feature dataset within the geodatabase.
Solution or Workaround
To eliminate this problem, move the relationship class into a feature dataset prior to creating the replica.
  • This can be done in ArcCatalog by dragging and dropping the relationship class into the feature dataset.
    Make sure all running services or programs that would create a lock on the geodatabase are stopped or disconnected.
Article ID:000010673
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
