BUG
Select statements issued against a multiversioned view in DB2 and Informix return base table information
When using a multiversioned view against versioned data in a DB2 or Informix database, issuing a SELECT statement against the view without first setting the geodatabase version returns only the information in the base table.
Cause
The multiversioned view is not defaulting to the DEFAULT geodatabase version.
Workaround
Always set the version before issuing a SELECT statement against the multiversioned view. This must be done before every SELECT statement.
For DB2, call the sde.setcurrentversion stored procedure to set the geodatabase version.
For Informix, execute the sde.set_current_version function.
For more information on working with multiversioned views, see the ArcGIS Desktop Web Help topic, "Using multiversioned views", listed in the Related Information section below.
  • For DB2, the syntax to call the sde.setcurrentversion stored procedure is as follows:
    CALL sde.setcurrentversion('<version_name>',?,?)
  • For Informix, the syntax to execute the sde.set_current_version function is as follows:
    EXECUTE FUNCTION sde.set_current_version('<version_name>')
Article ID:000010656
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
