Frequently asked question
Can adding a spatial index aid in performance when the operating system is a factor?
Answer
Performance of ArcGIS may be negatively affected depending on the operating system it is installed on and the resources allocated for it. In cases like this, one suggestion to help increase performance is to add a Spatial Index to the data. ArcGIS uses these spatial indexes to quickly locate features in feature classes.
To add a Spatial Index:
1. Start ArcCatalog.
2. Navigate to the location of the shapefile.
3. Right-click the shapefile and select Properties.
4. Select the Index tab.
5. Click the Add button in the Spatial Index section.
Article ID:000010650
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
