English
Bug: JTX 9.3 Add Data does not connect to the correct data workspace
The JTX 9.3 Add Data connects to the last Database Connection rather than the correct data workspace configured within JTX.
Cause
This is a known issue that occurs when there is no node in ArcCatalog containing the JTX connection files. This generally occurs by deleting the C:\ node, or by changing the location of the JTX database connection files.
Workaround
Add a node in ArcCatalog pointing to the JTX database connection folder, or one of its parent folders.
If JTX is installed in the default location, and the JTX database connection folder has not been moved, type C:\ into the location field in ArcCatalog and press Enter.
