BUG
The 'Polygon Feature Class From Lines' command does not import records from fields with an assigned domain
A polygon feature class produced in ArcCatalog by right-clicking a feature dataset and selecting 'Polygon Feature Class From Lines' does not preserve the records from fields in the label point feature class that have a domain assigned.
Cause
This is a known issue.
Workaround
Use the 'Feature to Polygon' tool in ArcToolbox > Data Management Tools > Features toolset to create the polygons and specify the point feature class as the label feature.
    Article ID:000010638
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
