BUG
The Query Attributes Task closes unexpectedly after clicking OK on the Form Entry Editor in Visual Studio
**This issue has been resolved in ArcGIS 9.3.1 Service Pack 2.**
When configuring the Query Attributes Task in Visual Studio, the task configuration dialog box closes unexpectedly when creating multiple Query Entries. Clicking OK on the Form Entry Editor crashes the Query Attributes Properties dialog box and the edits are not saved.
This problem does not occur when only one Query Entry is defined.
This issue applies to creating Web applications using the 9.3.1 version of ArcGIS Server Web ADF for the Microsoft .NET Framework.
Cause
This is an issue when using version 9.3.1.
Workaround
After each Query Entry defined, click OK on the Query Attributes Properties dialog box to close the configuration dialog box, and save the edits.
Continue to click OK and close this dialog box after each Query Entry created.
    Article ID:000010628
    Software:
    • ArcGIS Server
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
