PROBLEM
In Google Earth 4.3 or later, if a single layer is added from a WMS service (published using ArcCatalog or Server Manager) as an Image Overlay, the layer does not display. Instead, an 'X' appears on top of the globe.
The mandatory parameter ‘styles’ is not defined/set when a single layer is added.
Get help from ArcGIS experts
Download the Esri Support App
