English
Bug: When installing the ArcGIS plugins for Eclipse, the installation process hangs without completing the installation
When installing the ArcGIS plugins for Eclipse, the installation process hangs without completing the installation.
Cause
The Doc plugin on install is memory intensive and the default 256M in the eclipse.ini file is not enough memory for install.
Workaround
Edit the eclipse.ini file.
  1. Browse to the Eclipse folder and open the eclipse.ini file in Notepad or another text editor. Increase the memory specified in the file by increasing the -Xmx setting.
    -vmargs
    -Xms40m
    -Xmx512m
    Increasing the memory allows the plugins to install.
