English
How To: Match a user profile to folders in HKEY_USERS
Summary
Instructions provided describe how to identify which folder stored in the registry under HKEY_USERS is associated with each user profile on the computer.
The Security Identifier (SID) is a unique name (an alphanumeric character string) that is assigned by a Windows Domain controller during the login process that is used to identify a user.
This procedure enables administrators to make modifications to specific user profiles located in HKEY_USERS, mimicking those found in HKEY_CURRENT_USER when that user is logged in.
Procedure
  1. Expand HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList.
  2. Select each folder individually and look at the 'ProfileImagePath' key to identify the user profile associated with the selected folder:
    [O-Image] Example SID key
    The folder name in the above example; it is S-1-5-21-2060139532-2050374463-2073913816-1157.
  3. Expand HKEY_USERS\<folder>. In this example, HKEY_USERS\S-1-5-21-2060139532-2050374463-2073913816-1157. This is that user's HKEY_CURRENT_USER. Proceed with the desired modification:
    [O-Image] HKEY_USERS\
Related Information
