PROBLEM
Task menus are white in the Web Mapping Application when using Internet Explorer 8
When displaying a Web Mapping Application in Internet Explorer 8, menus containing tasks will be entirely white and the tasks cannot be opened.
[O-Image] White Task Menu IE8
This issue applies to Web Mapping Applications built with ArcGIS Server Web ADF for the Microsoft .NET Framework.
Cause
This is a known issue with the ASP.NET menu control when it renders in Internet Explorer 8.
Solution or Workaround
This issue can be addressed by installing a hotfix from Microsoft.
  1. Open the following article from the Microsoft Knowledge Base: KB962351 The pop-out menus are not displayed when you use Internet Explorer 8.0...
  2. Navigate to the hotfix that matches the operating system of the Web server being used.
    The prerequisite for the patch on Windows XP or Windows Server 2003 is Microsoft .NET Framework 2.0 Service Pack 2 (SP2).
  3. Download and install the hotfix.
Article ID:000010560
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
