English
How To: Remove an instance from ArcGIS Server using the AddInstance utility
Summary
Instructions provided describe how to remove an instance of ArcGIS Server using the AddInstance utility. The AddInstance utility is included with the ArcGIS Server product in <ArcGIS Install>\DotNet.
Procedure
  1. Start the AddInstance utility (<ArcGIS Install>\DotNet\AddInstance.exe) and click the Modify button.
  2. Highlight the instance to be removed.
  3. Click Remove.
  4. Click Ok.
Related Information
