ERROR
HTTP Status 503 - Web services handler not initialized
Error Message
When accessing a Web service endpoint or attempting to make an Internet connection to the ArcGIS Server Map services for the Java platform, the following error message is displayed:
"HTTP Status 503 - Web services handler not initialized"
Cause
The Java Web service handler is unable to connect to the ArcGIS Server Object Manager (SOM) process.
Solution or Workaround
To fix this error, run the ArcGIS Server Post Install Program. The instructions for the various platforms are provided below.
UNIX/Linux Platform:
1. Log in as the root user.
2. Open a terminal console and change directory to the ArcGIS installation folder.
3. Change the directory to the scripts folder.
4. Run the ServerConfig script.
Windows:
1. On Windows, click Start > All Programs > ArcGIS > ArcGIS Server for the Java Platform > GIS Server Post Install.
2. For help on running the post install, refer to the Administering the server > Getting started after install topic in ArcGIS Server Web help.
After completing the above steps for the corresponding platform, launch a new Web browser session and access the following URL:
http://[host_name]:8399/arcgis/services?wsdl
This URL returns an XML document indicating that the Web services handler is now working properly.
Article ID:000010551
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
