PROBLEM
The ArcGIS License Manager entry does not show up in Add/Remove programs with the keyless ArcGIS License Manager
The entry for ArcGIS License Manager does not appear in Add/Remove programs after installing the keyless version of ArcGIS License Manager.
Cause
The 'arcgis9x' folder from a previous installation of an ArcGIS License Manager still exists in C:\Program Files\ESRI\License.
Solution or Workaround
1) Delete the 'arcgis9x' folder located in C:\Program Files\ESRI\License.
2) Reinstall the keyless version of ArcGIS License Manager using the LMSetupKeyless.exe file.
    Article ID:000010550
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
