PROBLEM
Clip tool for raster datasets produces incorrect results
The Clip tool for raster datasets appears to produce incorrect results, the tool's dialog box reports an error when coordinate values for spatial extent are manually entered.
Cause
This issue is generally experienced when the extent values specified for the clip are based on a different coordinate system than that of the raster dataset. For example, the coordinates were obtained from the data frame's display, which may use a different spatial reference than the raster dataset.
Solution or Workaround
Specify the clip extent values using coordinates associated with the projection of the raster dataset.
  • Alternatively, consider using a polygon to define the area to be clipped.
Article ID:000010534
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
