Frequently asked question
Can ArcGIS Business Analyst Server be installed remotely?
Answer
Yes, at version 9.3, ArcGIS Business Analyst Server allows an administrator/user to deploy the installation remotely.
To install ArcGIS Business Analyst Server remotely, the administrator needs to perform an admin install. An admin install uses the Windows Installer (MSI) technology.
ArcGIS Business Analyst Server version 9.3 has two Setups. One installs the Business Analyst Data, and the other installs the server features. The MSI command for both Setups has the same syntax:
msiexec /A <path to the setup>\setup.msi
An admin install can be created using the above MSI command. This command can also be executed silently using the following format:
msiexec /A <path to the setup>\setup.msi /qb TARGETDIR=<the location where you want the admin created>.
The TARGETDIR, in the above example, can be a network location.
The admin install sets up the structure needed to run the Setup. Execute the Setup from this location instead of the DVDs.
This is useful if:
▪ Accessing a remote server
▪ Or accessing a server that has no media drives.
Perform the admin install over a network drive, then map that network drive to the remote server and begin the installation.
Article ID:000010527
Software:
  • ArcGIS Business Analyst Enterprise
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
