English
Error: GLB12.tmp has encountered a problem and needs to close. We are sorry for the inconvenience
Error Message
After installing ArcGIS Desktop using the 'Register now using the Internet (Recommended)' option to authorize the software returns the following error:
[O-Image]
Cause
This error is generated when European language characters, such as the umlaut (e.g., �), are used to fill out the parameters required for registering ArcGIS Desktop over the Internet.
Solution or Workaround
There are two ways to work around this issue:
  • Visit service.esri.com, and select the 'Product Registration' tab, register ArcGIS online, and receive an authorization file by way of e-mail from ESRI. Use the authorization file to complete the registration of ArcGIS Desktop using the option 'I have received a license file from ESRI and am ready to complete the registration process' in the Desktop Administrator.
  • Do not use European characters such as umlauts when registering ArcGIS Desktop.
