English
How To: Set folder permissions for Projects Upload/Download
Summary
Business Analyst Server requires certain permissions to be set for the folders in order to publish projects and data successfully.
Procedure
Permissions are needed for the folders listed below:
  • Temp folder
  • arcgisoutput folder
  1. Set Read/Write permissions for 'Everyone' for the Temp folder.
    1. Navigate to the Temp folder.
      The Temp folder is typically set in the Operating System.
    2. Right-click the Temp folder, and select Properties on the context menu.
    3. In the Temp Properties dialog box, click Security.
    4. If the user Everyone does not exist, click Add to add it.
    5. With user Everyone selected, check Read and Write in the Allow column.
    6. Click Ok.
  2. Set Read/Write permissions for 'Everyone' for the arcgisoutput folder.
    1. Navigate to the argisoutput folder on the server.
    2. Right-click the arcgisoutput folder and select Properties on the context menu.
    3. In the arcgisoutput Properties dialog box, click Security.
    5. Select user Everyone, check Read and Write in the Allow column.
    6. Click OK.
