After uninstalling ArcGIS Business Analyst 9.3 Desktop extension, some data folders in ArcGIS Business Analyst Server Data - 2008 are missing; even though, ArcGIS Business Analyst Server Data - 2008 was not uninstalled.
Cause
Uninstalling ArcGIS Business Analyst 9.3 Desktop extension uninstalls some data folders that are installed by ArcGIS Business Analyst Server Data - 2008 setup.
Solution or Workaround
The missing folders can be reclaimed by running the Repair process.
To run the Repair process:
- In Windows, select Start > Control Panel.
- Select Add or Remove Programs.
- Select ArcGIS Business Analyst Server Data - 2008.
- Select Change.
This launches the ArcGIS Business Analyst Server Data - 2008 Setup process. - Select Repair.
This repairs the ArcGIS Business Analyst Server Data - 2008 installation. It reinstalls the data folders removed by the uninstall of ArcGIS Business Analyst 9.3 Desktop extension.
