English
FAQ: Will ArcGIS Server services running in low isolation reduce the number of gsrvr processes?
Question
Answer
No. Running ArcGIS Server services in low isolation reduces the number of ArcSOC.exe processes, but there is still one gsrvr process for every instance that is running. Therefore, using low isolation does not change the number of gsrvr processes that are created.
Related Information
